Define trials and measurements that can be taken for a can type vertical pump
kbkjnr
Petroleum
GB
Good day
Please I need some advise on how I can define trials, measurements and aims (what to record) for a pump that was taken out of service for derating and is now coming back. WHat trials can i carry out to make sure the derating has been succesful and how can i measure these trials.
Michael
Differential head vs flow over a series of flow points?
Measure electrical input current to calculate efficiency?
That is about it.
Head and flow at 4 or 5 points within the preferred operating range and good motor measurements (V, A, per phase, and real power) while you do it.
The guys that worked on it didn't do any testing?
When you say derating, are you speaking of impeller trimming? I'm not familiar with vertical can pumps specifically.
The pump manufacturer would typically have pump curves for each impeller trim. Individual testing of pumps isn't always necessary.
Common problem with vertical can pumps is shaft vibration and the consequent loads imposed on bearings and shaft seals, especially on pumps with many stages. Ask a mech engineer to help.
Just another spin the wheels post, nearly 1 month and not a word from the OP.
