How to find the parent of the linked_face in VB ?
PSI-CAD
Computer
FR
Withe the following lines, I am able to find all "LINKED_FACE' in part
For Each primitive As Features.Feature In maquette.Features
If primitive.FeatureType.ToString = "LINKED_FACE" Then
echo(primitive.FeatureType)
End If
Next
Now, I would like to find the parent of the linked_face
Thanks in advance
Didier
Didier Psaltopoulos
UF.Wave.AskLinkSource will give you the source entity given a wave link feature. The lines of code below are from an old journal I have; if all goes well, it will give you the tag of the source entity and the name of the part that owns it.
Code:
Dim theSourceEntityTag As NXOpen.Tag = NXOpen.Tag.Null
Dim owningSourcePartTag As Tag = NXOpen.Tag.Null
Dim allowLoad As Boolean = True
Dim owningPartName As String = ""
Try
    '.AskLinkSource throws error if link is internal to the part being processed
    '(simple hole, mirror geometry)
    theUfSession.Wave.AskLinkSource(theFeature.Tag, allowLoad, theSourceEntityTag)
    theUfSession.Obj.AskOwningPart(theSourceEntityTag, owningSourcePartTag)
    theUfSession.Part.AskPartName(owningSourcePartTag, owningPartName)
www.nxjournaling.com
Hi Cowski
Forget my previous post, I succeed with your explanation, thanks a lot
Didier Psaltopoulos
