Multi step analysis in FEA
Apoorva Tyagi
Student
DE
Hello Everyone,
I am running a multi-step analysis for a drivetrain. The first step is used to create a contact between gears by controlling rigid body motions and the second step is used to apply the drive torque.
The question I have is will the stresses that are generated in the first step propagate to the second step or the second step starts with zero stress?
Are you talking about Abaqus ? Is geometric nonlinearity enabled ? Is plasticity defined ? Make a simple test to check how the results are carried over to subsequent steps.
Hello, yes. Generally in ABAQUS contact interactions defined in the initial step propagates to the next step
