need to calculate the load for a co
need to calculate the load for a cooling tunnel.
Line max speed is 800 kg/hr
Candy SKU ranging from 3.0g to 8.0g
15 Tr unit is already installed.
want to increase capacity for Dt (38c to 15c)
RH 30 to 35
need how much more Tr of capacity is required.
cooling time is 8 to 10 mins.
kindly provide answers with formula and solution.
Temperature inside the tunnel is 12 to 14 c
inlet temperature of Candy over the conveyer is 38c and want to reduce it to 15c.
Length of tunnel is 22ft
Height is 3ft Width is 6ft
RH 30 to 35
RE: need to calculate the load for a co
TTFN (ta ta for now)
Good Luck,
Latexman
Well your choices are:
Try working something out yourself and then post the results
Ask someone where you work how to do it
Pay an experienced engineer to calculate it
I can't work out what your current system is?.
Good Luck,
Latexman
