We recently migrated to NX1926 and the "partially shaded" feature is no longer working in this version when we have a set assembly in modeling.
Do I need to change some setting for it to work?
Newer versions of NX have a new load option, "minimally load", which is set as the new default. I don't know if this is the source of your issue, but I'd suggest changing the load option to "fully load"; or, if you have a large assembly, "partially load". If your assembly is already opened and loaded, you can right click on a component in the assembly navigator and use "load fully" (or "load exact", something to that effect) to fully load the component.
