Tehran Oil Refinery - Fire moment
5
Nothing is more fairly distributed than common sense: no one thinks he needs more of it than he already has. Rene Descartes
RE: Tehran Oil Refinery - Fire moment
It;s bit hard to be sure, the above may be from the fire reported to be
Quote (https://twitter.com/IranNW/status/1400114646787444...)
Jun 2 - Tehran, #Iran Large fire reported at the Tondguyan Oil Refinery in Tehran. The Director-General of Tehran's Crisis Office said an emergency liquefied gas line at the Tondguyan Refinery in Tehran has caught fire.
Reported to involve 18 oil storage tanks. https://english.alarabiya.net/News/middle-east/202...
In the video in the Instagram link ((McDermott1711's post), you can see that there was a partial failure allowing a cascade of ?? for an unknown period - certainly before the start of the video, prior to the complete ring failure. The containment was already saturated before the major release.
The tank in the middle failed in ring tension. Not sure what it contained, but it ignited instantaneously.
The Iranians are having a bit of bad luck recently, the poor things.
Is the movement caused by a camera on a mast, in the wind? I wrote a program about 30 years back to remove the motion so that the camera could be used for intrusion detection...
What was posted appears to be a handheld cellphone video taken of the closed-circuit security video playing back on a computer screen. If you watch, about halfway through the video the cellphone was moved back enough to see the edge of the monitor.
John R. Baker, P.E. (ret)
EX-'Product Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Thanks, John... didn't watch the entire clip...
The initial failure appears to be a seam splitting open between two rings of the tank. This probably weakened one of the rings which eventually ruptured. As to what caused the fire, we can only speculate but I would put my money on a ruptured conduit leading to some sort of electrical gear in the tank farm. Not sure what the protocol would be in a situation like this, but if I saw flammable liquids spilling, even into the containment area, the first thing I would consider would be to cut power to anything electrical near that containment area.
Irvine, CA
Siemens PLM:
UG/NX Museum:
I only saw "whitish liquid". The "black" appears to be the color of the inside walls of the tank.
Irvine, CA
Siemens PLM:
UG/NX Museum:
how much of their capacity has that taken out?
The only thing I understood in the video was “LPG”. It’d be great if someone could translate what is said in the YouTube video.
Good Luck,
Latexman
That bund looks pretty small but like most others it isn't built to handle a sudden catastrophic tank failure so that's why the spillage is so large.
Just as well it caught fire very rapidly. I wouldn't want it burning away under those LPG tanks. A BLEVE of those would be seen from space.
Being the liquid was "whitish" and it ignited as quickly as it did, it was some sort of refined product, perhaps gasoline or jet-fuel.
Irvine, CA
Siemens PLM:
UG/NX Museum:
Jet fuel isn't whitish its basically just diesel
Maybe it was naphtha, which can be colorless. Note that Iran produces over 3,400 metric tons of naphtha per year.
Irvine, CA
Siemens PLM:
UG/NX Museum:
I will make a wild guess here.
I think he is actually speaking very bad German, so you should talk to Lou Scannon.
He is saying something like this and now I will blame all the wrong words and spelling on the guy in the video.
In de zweitige komunine for them verletsstelle service mecher base ma kreuz LPG #¤/= ? %#""#¤&? #¤/= ? baro bar haupsytem Schlüssel.
In the second tank is the mechanical service distribution point for the LPG then something blablabla I cant hear/understand what he is saying and there is the pressure bar and main system, key.
B.R. A
Albert Einstein
From the YouTube video notes
Quote (https://www.youtube.com/watch?v=7wA9SHbefZk)
A terrible fire in Tehran's refinery..a terrible explosion 💣💣💣💣
#Fire 🔥 breaks out at Tehran Oil #Refinery ( The fire erupted at the state-owned Tondgooyan #Petrochemical Co. to the south of Tehran)
A huge fire broke out at an oil refinery in the southern part of the Iranian capital
#Tehran on #Wednesday (2 June 2021)
According to local reports 18 storage tanks caught fire in Tehran Refinery fire, IRAN (2 June 2021) ، 11 people were injured, with four in hospitals.
This scene is due to the disintegration of the tank shell due to oxidation decay. It starts from one end of the Joint Weld.
None of the protective layers could prevent the massive leakage of hydrocarbon material from such an accident.
The problem of tank maintenance and non-compliance with welding standards over time and inspection and review according to the checklists of the mechanical unit , suspect non compliance with the MI( Mechanical Integrity ) element of
PSM.
TTFN (ta ta for now)
I reckon he is speaking Farsi.
They have loads of different lingos in the country so for most of the population they have to be able to communicate in Farsi but it may be their 3 or 4th lingo from birth.
It always a bit embarrassing for me hearing my fellow nationals going on about the accents and standard of English in these places. Most brits only speak one lingo English and for some of them I struggle with the accent and diction never mind a second language speaker which may actually be a 3rd to 6th in these sort of regions.
There is a a lot of Turkish lingo used and they mix and match some of them.
Politics aside I have always found the Irian people absolutely lovely, warm and helpful. Love their food.
Well I will retract my former statment and say, he is speaking German.
The three first worlds it's quit clear, I am not good at German refinery terminologi but I am sure.
He is explaining to someone where the different control and monitoring devices are on that second tank which he is pointing at with the mouse pointer.
BR A
Albert Einstein
Quote (Alistair Heaton)
Second that. I worked on a project with someone from Iran who hit me with this from Marjane Satrapi
"If I have one message to give to the secular American people, it’s that the world is not divided into countries. The world is not divided between East and West.
You are American, I am Iranian, we don’t know each other, but we talk together and we understand each other perfectly.
The difference between you and your government is much bigger than the difference between you and me.
And the difference between me and my government is much bigger than the difference between me and you. And our governments are very much the same."
That's just what there instruction manuals are in and as there are no local words for the equipment they have taken in the German into the local lingo.
Yes I was actually trying to find a manual or a better technical translation site, google translate does not cut it here.
Just to confirm my statment that he speaks German.
/A
Albert Einstein
Chinese is even more interesting... they may have 200 different dialects where one person cannot talk to another... but, they have the same written language. I can write a note to Freddie, even if I cannot talk to him.
The Persian thing is a huge political fight in the region it has ramifications I don't really understand. But it also involves clashes between various flavours of Islam and which one has supremacy.
It reminds me to be honest of the subtle nonsense that goes on in Scotland between the Protestants and the Catholics and as an east coaster Aberdonian I don't really understand that, I don't have much chance with Islam either.
Yeah, pretty bad, that; I was around 10 or 11 when I visited my mom at the bank in Chinatown and this old lady came in speaking a dialect that baffled everyone but me, since it was the same dialect my babysitter spoke. And the dialect is from the same province where Cantonese is common: https://en.wikipedia.org/wiki/Taishan,_Guangdong
We did have a Persien technical director not sure it was any different then having a Swedish one.
We have a lot of different people with different nationalities at the factory in most cases it's no different from Swedes.
The only ones I can remember that stood out a bit was actually French, we hade this division manager, he came visiting every month, threatening people that he would sack them, which isn't easy in Sweden if not impossible.
And then this Frenchman in the produktion, he got so angry with me once that his colleagues had to hold him so he wouldn't jump on me.
He hade manipulated the security system with some mechanical contraption, so I toke it away and threw it in the
scrap press.
I told them a hundred times it wasn't ok, they always managed to hide it from me, but not that time.
The majority are Sunni muslims but there is also Christians, Jews, Zoroastrianism, Bahá'ís and Mandeism.
Zoroastrianism was the old state religion.
It's devis is "Good thoughts, good words, good deeds".
/A
Albert Einstein
Yes you are right IRstuff didn't read properly. smile
BR A
Albert Einstein
My God's fine... too bad about yours...
I suspect the written language comes from Mandarin... the official language of government, but I don't know. Way back, when I was an engineering student, I had a T-shirt with Viet Cong (in Chinese symbols)... it was a hoot... only reaction was from the Chinese students at the U.
That's the whole daft thing its all the same bloody GOD or big man as us jocks like to call him.
There is an Irish Catholic priest in my local and we have had a few discussions about this stupidity.
I spent my youth a few times in a PIG in NI and like most solders of the period felt like we were piggy in the middle and actually supported a united Ireland. Still do to this day but would never wish those animals in NI on the southern Irish.
Sean has some great dits about when he was in Manchester and shared the chaplaincy in the Cat A prison with an ex UK SAS padre. Who in his first week went in solo with some gang land nutter who was in for life who thought it was a good idea to take him out.... He carried the same bible with blood stains on it for his two years there, and nobody touched him again. Even the prison officers were surprised at the level of violence that was dealt out in such short time period by one man with no broken bones. He did say though to the guy "I have killed more than you and buried more than you and I am not talking about the ones they know about. Lord please forgive me for educating this young man". Any thing kicking off afterwards and he was there, he would just go in solo with his book and everyone calmed down. Sean said he couldn't do it.
Getting a little bit off topic here....
LI I agree but if you have ever met the same as us Iranians its pretty horrendous for them. Haven't been there for years but will always remember my time there.
Lovely people.
Well the tank was motor welded where it broke, do not know how long ago.
LittleInch you must know what kind of instruments there are on those LPG containers?
BR A
Albert Einstein
Must have been very poor welding, as the force on the wall of a circular tank is small in that direction.
I think it was probably lots of corrosion rather than poor welding.
LPG domes like that just have pressure and temperature usually. Level they probably just do by pressure/weight.
They should be designed for a fire case but there may be distribution valves under the tanks which are more exposed.
They may not have considered that a wave of burning liquid would arrive and sit under the tank. Anyway it clearly didn't BLEVE otherwise we would have seen it by now.
Poor welding can lead to corrosion faster then a good weld, much faster.
BLEVE ?
/A
Albert Einstein
Confused messages coming from Tehran, but lots of mentions of an LPG leak/ due before the main fire. No mention though that a tank failed.
It may have been a large slops tank so maybe that was water coming out then when it failed the oil above the water layer got exposed.
The tank may have been exposed to a jet fire? Hence weakened and started leaking.
Well this is the conversation in the instagram yesterday.
I toke away who was saying what.
And now I can't get in anymore.
Of course I have no idea if this people have any real insight thus the reason I didn't post it before, take it for what it is.
Quote (Instagram link posts)
For this reason, there is a risk of collapse for other thoughts.
Only no one was under
Why are they laughing? Do not do your own thing
It was an explosion
It was an explosion to drop a bomb
Nothing special happened, it does not matter
It turns out that he is filming and waiting for the explosion
This is a crime in thought and its appearance explodes
Since when has oil waste been refueled?
Explosion card
Why should the storage of this oil waste be close to the city and the people when it is so dangerous?
The welder in the tank is made by a motor
Best Regards A
Albert Einstein
Sounds like someone who's never seen the inside of an oil refinery....
The refinery has been there 55 years - it's very likely the city has grown to encompass the refinery, not the other way around.
By looking at this picture, it seems that they didn't consider a dyke for the tanks and I recon the tanks was used primarily for water storage (and perhaps this is the reason we don't see a fire protection acting automatically for them).
I've heard that (due to sanctions) Iran can no longer sell its condensates (from natural gas refineries) and tried to store them everywhere possible and by reaching the end of storage capacity, the process of natural gas production is disturbed. And I guess this is why we see scheduled power outage in the country.
Google Map view of the tanks
Quote (IRstuff)
But, the photo does show a wall around these tanks, which is why the fire retardant is all contained in the vicinity?
Is the height enough?
I work in a hydrocarbon storage company. Due to the characteristics of the tank (floating roof tank) it must store gasoline or something similar with a low flash point.
The collapse of the shell is spectacular and the weld must be very weak for it to open like this. That tank is not a water or LPG tank.
It looks like the product is coming out of the envelope before the collapse and the explosion. Product leakage generates an explosive atmosphere.
After detecting the initial leak, they had to trigger the fire system to fill the area with foam. In addition to removing the electrical power from the area.
Mcdermott,
The bunds are typically sized for the largest tank and to contain its volume +10%. The safest way is for each tank to have its own bund, but that takes up a LOT of space so usually you find multiple tanks within a single bund so long as it is all the same product. Especially for tanks built in 1960's.
No bund wall I am aware of considers tank failure like we saw where you get a tidal wave of liquid.
From the garbled information we have I think this tank was possibly being used as a giant water separator, hence the flammable bit was higher than the leak area and maybe having water in a tank not designed for it has caused corrosion in a seam weld. There was also mention of an earlier LPG fire which may have stressed that tank - who knows?? Also the tank may have been repurposed over time as the reports mention this being a "slops" tank.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
