Electric car ship fire. 1
The fire is in the vicinity of the engine room. I'll give the electric cars the benefit of doubt for now. The small white dot to the right of the arrow is likely the engine room forward bulkhead. The other white dot to the left is a cargo hold bulkhead but the double bottom fuel tanks likely sit between the two bulkheads.
from https://www.marineinsight.com/shipp...-abandoned-after-fire-breaks-out-near-alaska/
According to Zodiac Maritime, the London-based company managing the ship, smoke was first seen coming from the stern area where electric vehicles were stored.
A fire safety director from the International Association of Fire Fighters said the way the CO₂ system failed to stop the blaze suggests the fire likely started from an electric vehicle battery.
Interesting that you chose to crop your picture to essentially not show where all the smoke was coming from
We had all seen where the smoke was coming from. I thought my markup looked tacky so I didn't use it. Maybe the bulkhead markings weren't as obvious as I thought. Anyways, the engine room occupies the red box and the fuel is in the blue box.
It might have got to the point that special electric vehicle and battery transport cargo ships are required.
With a method that can deal with battery fires
Maybe we need to treat electric cars like wine and age them for 6 months before selling them to the consumer. You know, get them a little more right in the bathtub curve.
There's nothing the literature that suggests lithium batteries have an infant mortality mechanism that results in thermal runaway, aside from latent manufacturing defects
Yes, latent manufacturing defects are a leading cause of infant mortality.
Infant mortality has a significantly higher failure rate, which is not supported in the case of these batteries.
Wonder what testing the batteries are subjected to and at what stage in the production cycle of a car.
I doubt the batteries have been through a single charge cycle before these cars end up on the ship.
Maybe you just haven't seen the evidence. (I haven't either on "these batteries" I don't even know what "these batterie ARE.)
But in the case of most manufacture item, especially complex ones with many components, the likelihood of failure in their infant life is much higher than that in the adolescent and young adult ages of the item. And lithium ion batteries that power electric vehicles are certainly what I would describe as complex manufactured items.
For example spinnging hard disk drives:
OK this isn't infant mortality, but here's an attempt to look at the the 500 cycle failure rate, note that out of a relatively small sample (~25) 4 are at 60% of their cycle 80 capacity, which means they are entirely reliant on the battery pack monitoring system to avoid overcharging in a large pack
I've never seen an r^2 of 0.1 being used for anything! It's a good thing he's got that failure at bottom left otherwise he'd have a gradient of 0.
The cars will have had some charge in order to be loaded, like they put in about 3 litres of petrol just to drive them on and off the vessel.
This looks like a typical car carries so the vehicle decks extend the full length of the vessel.
There are reports that the fire was detected on a vehicle deck and despite fire fighting they couldn't put it out and have abandoned ship.
Seems it's still floating.
Salvage team still en route
Probably best to dispose of the evidence and not make the general population aware of the environmental hazards that exist post battery fire ie the cleanup required to make the ship safe for human entry.
I'm just now reading through this thread, and my idea was tow it to shallow water, sink it until the fires go out, then raise it again. Looks like they omitted the "shallow water" part, though.
Ships can't rest on the bottom without sustaining massive damage. Any such vent would result in a total loss. Environmental agencies will sue to throw salt in the wound.
Modern ships are designed to be able to remain upright and stable with two compartments flooded. That might mean the ship sits another 5-10 feet lower in the water. There is still a lot of ship above that waterline with cargo.
