Lifting eye analysis procedure by Ansys
Hello everybody.
I am trying to analyze lifting eyes welded to a motor. I have analyzed with 2 different methods.
In the first method, I used springs as slings with the setting of behavior - Rigide.
In the second method, I used 3 remote points linked with each other as slings with the setting of behavior - Rigide. Others settings are similar.
And finally, I have gotten different results. For the first case, it is 336 MPa. And for the second is 170 MPa.
Could anyone tell me what approach is preferable for simulating slings using Ansys?
RE: Lifting eye analysis procedure by Ansys
Hand calculations in accordance with a lifting code are typically done to check the material above the hole (tear-out, bearing stress).
Did you manage to complete the model. If not confidential, will you be able to share the archived WB file with me. Thanks
