Hydrostatic bearing CFD analysis
Anurag K
The load rests on a base and the load has a recess on its bottom face.
The fluid is pumped into that recess; the pressure (Pt) builds up to a point where the force caused by the pressure over the recess area is enough to lift the load off the base. Once the load is lifted there is a pressure drop (Pr), and since the fluid is pumped into the recess the load floats on the fluid film.
I have attached a picture for reference.
I want to run a CFD analysis to see if the pressure distribution is uniform over the recess to keep load afloat, but I am having trouble to transfer the load's weight as external body force onto the fluid in the analysis. Please help me how to achieve it. And I also want to find the pressure drop (Pr) once the load is lifted and the distance by which the load is lifted.
Look like the easiest way will be to run a number of cases with different lifting height (in each case bearing runner surface is fixed and do not move)->different gaps where oil escapes, extract resultant force for each case and compare it with required load.
