Hello! I need same help to setup cutting condition for 12mm mild steel on Amada X1 laser. Overall cut is ok, but is burn the hols and slots. It melts the material. What would you change in condition to fix this problem? We using the condition 1 to pirce then start with 2 and run on 6.
