heat exchanger modeling
please your advice about the design of two pipes connected to the heat exchanger
below two examples
-1- anchor restraint at the end of two pipes
-2- anchor connected together with rigid element(0 weight)using connecting node
So, which example (1 or 2) best describes the real design of the model in caesar ii?
RE: heat exchanger modeling
what's CNODE?
Cnode is a term from Caesar II that allows you "connect" two nodes so that they move together. It's typically used with equipment nozzle with piping, so that the piping will displaced by the equipment flange growth/movement.
Method 2 will be most accurate and is the way the Caesar manuals recommend it. If you have known displacements/movements at the HE connections, you can use Method 1 with assigned displacements instead of anchors.
Consider a repost in the COADE, Inc: CAESAR II forum ...
MJCronin
Sr. Process Engineer
Is there any professional user of caesar can give us a clarification about this subject
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
