stability issue in designing virtual control law for auv
Hello everyone!
I need guidance in designing a virtual control law for path following using AUV model. The control law is attached in the figure. The code is not working (attached). I don't understand how to fix it. Could anybody help me?
RE: stability issue in designing virtual control law for auv
Matlab: https://www.eng-tips.com/threadminder.cfm?pid=575
When you re-post your question, it will also help immensely if you were to describe the architecture of your control system in more detail than that one diagram.
www.sparweb.ca
What design document/text are You referencing, RE that flow/path diagram??????????
NOTE.
My EE-EL-AV database shows there are LOTS of useful texts, documents and specification on this subject that could assist You. LOOK HARDER!
OK... but... Since my EE-EL-AV database was recently identified as a 'corporate trade secret', I can't release it, parts of it, or even list a few references from it... on this or similar non-corporate sites.
Yeah guys... I've had to do engineering liaison/backshop work in Electrical, Electronic and Avionic system items/elements over the decades... since most EEs & ELs are not always 'spark-chasers' [NOT repair/maintenance or failure-investigation oriented].
Regards, Wil Taylor
o Trust - But Verify!
clear all
clc
close all
pos=[0,0,0,0,0,0]';
posdesired=pos;
posseq=[pos];
e=[0;0;0;0;0;0];
II = e;
velocity=[0,0,0,0,0,0]';
tau=[0,0,0,0,0,0]';
% Kp=0.22*[1 0 0; 0 1 0; 0 0 1];
% Ki=0.063*[1 0 0; 0 1 0; 0 0 1];
Kp=-3*eye(6);
Ki=-2*eye(6);
% M=[1.1274 0 0; 0 1.1274 0; 0 0 1];
m=180;
Xudot=-30;
Yvdot=-110;
Zwdot=-80;
Ix=25;
Iy=29;
Iz=28;
Kpdot=-15;
Mqdot=-20;
Nrdot=-1;
M=[m-Xudot,0,0,0,0,0;
0,m-Yvdot,0,0,0,0;
0,0,m-Zwdot,0,0,0;
0,0,0,Ix-Kpdot,0,0;
0,0,0,0,Iy-Mqdot,0;
0,0,0,0,0,Iz-Nrdot
% D=[0.0414 0 0; 0 0.0414 0; 0 0 0.0568];
dif=[];
Ts=.01
posdseq=[];
vseq=[];
% for position estimation
for i=1:700
posold=pos;
vold=velocity;
% Rv=[cos(posold(3)) -sin(posold(3)) 0; sin(posold(3)) cos(posold(3)) 0; 0 0 1];
J1=[cos(posold(6))*cos(posold(5)) -sin(posold(6))*cos(posold(4))+cos(posold(6))*sin(posold(5))*sin(posold(4)) sin(posold(6))*sin(posold(4))+cos(posold(6))*cos(posold(4))*sin(posold(5));
sin(posold(6))*cos(posold(5)) cos(posold(6))*cos(posold(4))+sin(posold(4))*sin(posold(5))*sin(posold(6)) -cos(posold(6))*sin(posold(5))+sin(posold(5))*sin(posold(6))*cos(posold(4));
-sin(posold(5)) cos(posold(5))*sin(posold(4)) cos(posold(5))*cos(posold(4))];
J2=[1 sin(posold(4))*tan(posold(5)) cos(posold(4))*tan(posold(5));
0 cos(posold(4)) -sin(posold(4));
0 sin(posold(4))/cos(posold(5)) cos(posold(4))/cos(posold(5))];
% J2=[1 sin(90)*tan(90) cos(90)*tan(90);
% 0 cos(90) -sin(90);
% 0 sin(90)/cos(90) cos(90)/cos(90)];
Rv=[J1 zeros(3,3);zeros(3,3) J2];
%control law 1
e=[e posdesired-pos];
vref= Kp*e(:,end);
tau=Ki*(vref-vold);
% tau=Kp*(Rv'*Ki*e(:,end)-vold);
% II = II+(Ts/2)*(e(:,end-1)+e(:,end));
% tau=[tau Rv'*(Kp*e(:,end)+Ki*II)];
% Cv=[0 -1.1274*vold(3) 0;1.1274*vold(3) 0 0;0 0 0];
% Dv=D*diag(vold);
Cv=[0 -m*vold(6) m*vold(5) 0 -Zwdot Yvdot*vold(2);
m*vold(6) 0 -m*vold(4) Zwdot*vold(3) 0 -Xudot*vold(1);
-m*vold(5) m*vold(4) 0 -Yvdot*vold(2) Xudot*vold(1) 0;
0 -Zwdot*vold(3) Yvdot*vold(2) 0 (Iz-Nrdot)*vold(6) -(Iy-Mqdot)*vold(5);
Zwdot*vold(3) 0 -Xudot*vold(1) -(Iz-Nrdot)*vold(6) 0 (Ix-Kpdot)*vold(4);
-Yvdot*vold(2) Xudot*vold(1) 0 (Ix-Kpdot)*vold(4) -(Ix-Kpdot)*vold(4) 0];
Dv=[-200*abs(vold(1)),0,0,0,0,0;
0,-310*abs(vold(2)),0,0,0,0;
0,0,-250*abs(vold(3)),0,0,0;
0,0,0,-80*abs(vold(4)),0,0;
0,0,0,0,-80*abs(vold(5)),0;
0,0,0,0,0,-25*abs(vold(6))];
% gn=[0,0,0,0.04*180*9.8*cos(90)*sin(posold(4)),0.04*180*9.8*sin(90),0]';
pos=posold+Ts*Rv*vold;
velocity = vold - Ts*inv(M)*(Cv+Dv)*vold+Ts*inv(M)*tau(:,end);
if (i>=5 && i< 280)
posdesired=[2 0 0 0 0 0]';
elseif(i>=280 && i<500)
posdesired=[2 2 0 0 0 0]';
else
posdesired=[0 0 0 0 0 0]';
end
i
posseq=[posseq,double(pos)];
vseq=[vseq,double(velocity)];
posdseq=[posdseq,posdesired];
dif=[dif,posdesired-pos];
plot(posdseq(1,:),posdseq(2,:),'g--')
hold on
plot(posseq(1,:),posseq(2,:))
pause(10^-5)
end
It seems best as an example warning to others of how not to do any software development.
Cheers
Greg Locock
Cheers
Greg Locock
This does not pass my sniff-check.
Regards, Wil Taylor
OK, let's close this one.
Cheers
Greg Locock
