stability issue in designing virtual control law for auv
Waseem Akram
Computer
Sep 14, 2020
1
Hello everyone!
I need guidance in designing a virtual control law for path following using AUV model. The control law is attached in the figure. The code is not working (attached). I don't understand how to fix it. Could anybody help me?
Waseem... The reference You enclosed led to a file... 'auv_vinput_11sep.m'… that I could NOT [safely] open.
What design document/text are You referencing, RE that flow/path diagram??????????
NOTE.
My EE-EL-AV database shows there are LOTS of useful texts, documents and specification on this subject that could assist You. LOOK HARDER!
OK... but... Since my EE-EL-AV database was recently identified as a 'corporate trade secret', I can't release it, parts of it, or even list a few references from it... on this or similar non-corporate sites.
Yeah guys... I've had to do engineering liaison/backshop work in Electrical, Electronic and Avionic system items/elements over the decades... since most EEs & ELs are not always 'spark-chasers' [NOT repair/maintenance or failure-investigation oriented].
Regards, Wil Taylor
o Trust - But Verify!
WKT - I opened it; it's just matlab. I have FreeMat, which dies and tanks the application instead of reporting errors; not surprised since development of FreeMat seems to have also died.
clear all
clc
close all
pos=[0,0,0,0,0,0]';
posdesired=pos;
posseq=[pos];
e=[0;0;0;0;0;0];
II = e;
velocity=[0,0,0,0,0,0]';
tau=[0,0,0,0,0,0]';
% Kp=0.22*[1 0 0; 0 1 0; 0 0 1];
% Ki=0.063*[1 0 0; 0 1 0; 0 0 1];
Kp=-3*eye(6);
Ki=-2*eye(6);
% M=[1.1274 0 0; 0 1.1274 0; 0 0 1];
m=180;
Xudot=-30;
Yvdot=-110;
Zwdot=-80;
Ix=25;
Iy=29;
Iz=28;
Kpdot=-15;
Mqdot=-20;
Nrdot=-1;
M=[m-Xudot,0,0,0,0,0;
0,m-Yvdot,0,0,0,0;
0,0,m-Zwdot,0,0,0;
0,0,0,Ix-Kpdot,0,0;
0,0,0,0,Iy-Mqdot,0;
0,0,0,0,0,Iz-Nrdot
% D=[0.0414 0 0; 0 0.0414 0; 0 0 0.0568];
dif=[];
Ts=.01
posdseq=[];
vseq=[];
% for position estimation
for i=1:700
posold=pos;
vold=velocity;
% Rv=[cos(posold(3)) -sin(posold(3)) 0; sin(posold(3)) cos(posold(3)) 0; 0 0 1];
J1=[cos(posold(6))*cos(posold(5)) -sin(posold(6))*cos(posold(4))+cos(posold(6))*sin(posold(5))*sin(posold(4)) sin(posold(6))*sin(posold(4))+cos(posold(6))*cos(posold(4))*sin(posold(5));
sin(posold(6))*cos(posold(5)) cos(posold(6))*cos(posold(4))+sin(posold(4))*sin(posold(5))*sin(posold(6)) -cos(posold(6))*sin(posold(5))+sin(posold(5))*sin(posold(6))*cos(posold(4));
-sin(posold(5)) cos(posold(5))*sin(posold(4)) cos(posold(5))*cos(posold(4))];
J2=[1 sin(posold(4))*tan(posold(5)) cos(posold(4))*tan(posold(5));
0 cos(posold(4)) -sin(posold(4));
0 sin(posold(4))/cos(posold(5)) cos(posold(4))/cos(posold(5))];
% J2=[1 sin(90)*tan(90) cos(90)*tan(90);
% 0 cos(90) -sin(90);
% 0 sin(90)/cos(90) cos(90)/cos(90)];
Rv=[J1 zeros(3,3);zeros(3,3) J2];
%control law 1
e=[e posdesired-pos];
vref= Kp*e:),end);
tau=Ki*(vref-vold);
% tau=Kp*(Rv'*Ki*e:),end)-vold);
% II = II+(Ts/2)*(e:),end-1)+e:),end));
% tau=[tau Rv'*(Kp*e:),end)+Ki*II)];
% Cv=[0 -1.1274*vold(3) 0;1.1274*vold(3) 0 0;0 0 0];
% Dv=D*diag(vold);
Cv=[0 -m*vold(6) m*vold(5) 0 -Zwdot Yvdot*vold(2);
m*vold(6) 0 -m*vold(4) Zwdot*vold(3) 0 -Xudot*vold(1);
-m*vold(5) m*vold(4) 0 -Yvdot*vold(2) Xudot*vold(1) 0;
0 -Zwdot*vold(3) Yvdot*vold(2) 0 (Iz-Nrdot)*vold(6) -(Iy-Mqdot)*vold(5);
Zwdot*vold(3) 0 -Xudot*vold(1) -(Iz-Nrdot)*vold(6) 0 (Ix-Kpdot)*vold(4);
-Yvdot*vold(2) Xudot*vold(1) 0 (Ix-Kpdot)*vold(4) -(Ix-Kpdot)*vold(4) 0];
Dv=[-200*abs(vold(1)),0,0,0,0,0;
0,-310*abs(vold(2)),0,0,0,0;
0,0,-250*abs(vold(3)),0,0,0;
0,0,0,-80*abs(vold(4)),0,0;
0,0,0,0,-80*abs(vold(5)),0;
0,0,0,0,0,-25*abs(vold(6))];
% gn=[0,0,0,0.04*180*9.8*cos(90)*sin(posold(4)),0.04*180*9.8*sin(90),0]';
pos=posold+Ts*Rv*vold;
velocity = vold - Ts*inv(M)*(Cv+Dv)*vold+Ts*inv(M)*tau:),end);
if (i>=5 && i< 280)
posdesired=[2 0 0 0 0 0]';
elseif(i>=280 && i<500)
posdesired=[2 2 0 0 0 0]';
else
posdesired=[0 0 0 0 0 0]';
end
i
posseq=[posseq,double(pos)];
vseq=[vseq,double(velocity)];
posdseq=[posdseq,posdesired];
dif=[dif,posdesired-pos];
plot(posdseq(1,:),posdseq(2,:),'g--')
hold on
plot(posseq(1,:),posseq(2,:))
pause(10^-5)
end
does this feel like homework to you ?
Really bad homework - a control system problem with a failed software implementation in Matlab that is being asked about in a forum that usually deals with neither one?
It seems best as an example warning to others of how not to do any software development.
FWIW it runs in Octave. Personally I'd have thought with a flowchart like that Simulink would have been the goto app. Anyway, have you checked that your AUV block works by itself? I'm not going to look at it, it is the sort of crap code I churn out as a hack.
Cheers
Greg Locock
"it is the sort of crap code I churn out as a hack." … greg, the self confessed hack ! (smile)
Spar Web recommended redirect of the question to another [more appropriate] forum... but from what I can tell the OP has NOT done so... and has not logged-on since the initial posting.
This does not pass my sniff-check.
Regards, Wil Taylor
rb1957 - Unfortunately the motto of my life seems to be "If it is stupid but it works, it isn't stupid".
OK, let's close this one.
Cheers
Greg Locock
