Hydrotest of internal piping in vessels
Hi everyone
Is it necessary to take hydrotest for internal piping in vessels or drums?
RE: Hydrotest of internal piping in vessels
Mehran,
Your question is not clear enough. Do you mean if you need to account for it in an analysis or are you asking that it must be conducted? It is mandatory to calculate the value of a hydrostatic pressure test, see UG-99 of Division 1. I know too little about your problem to decide whether or not the testing conditions must be evaluated for the structure. You might want to take a look at appendix 46 (46-3(d)) of Division 1 as well.
Dear Mehran1977,
Of course. Test requirements would be as per the piping code.
Regards.
DHURJATI SEN
Kolkata, India
Is the piping wholly within the vessel?, i.e. can you get a differential pressure in operation?
If not then no it doesn't need it, but if the piping extends beyond the pressure vessel then yes.
Very difficult to say without a P&ID or piping drawing.
It may look as:
- If the internal pipe is a "non-pressure" part, the test is not required.
- If it's like an exchanger with internal tubes, which are pressure parts, the test is required.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
