Internal diameter of Economizer Header - HRSG
hernanrmz
Hello everyone,
Is there any design rule to define the internal diameter of HRSG Economizer headers?
In two reference Boilers books, I have found that the axial velocity inside the Economizer header should be less than 6 m/s?
I think there should be a minimum internal diameter to ensure correct distribution of water within the tubes.
Thanks for your help.
Best regards.
6 m/s is a standard threshold even mentioned in corrosion handbooks regarding cracking of air coolers.
Boiler manufacturers normally do not share such data as these are proprietary in nature.
You need to do a flow calc to determine the minimum I.D. in addition to tubing arrangement.
