Report all links in assembly 1
niedzviedz
PL
I wanna process all parts in assembly to report all links and then search for parent. Now I have journal which was created to report all broken links. Below is some code:
Code:
Sub reportComponentChildren1( ByVal comp As Component, ByVal indent As Integer)
Dim workPart As Part = theSession.Parts.Work
Dim dispPart As Part = theSession.Parts.Display
For Each child As Component In comp.GetChildren()
	Dim MyPart As Part = child.Prototype.OwningPart
	Try
		if child.IsSuppressed = true then
			Continue for
		end if
		Catch e11 As Exception
		theSession.ListingWindow.WriteLine("Failed: " & e11.ToString)
	end try
	If LoadComponent(child) Then
		Dim sourceTag As Tag
		Dim Parentname as string
		Dim linkBroken As Boolean = True
		For Each theFeature as Features.Feature In MyPart.Features
			If theFeature.FeatureType.Contains("LINKED") Then
				theUfSession.Wave.IsLinkBroken(theFeature.Tag, linkBroken)
				If linkBroken Then
					theUfSession.Wave.AskbrokenLinkSourcepart(theFeature.Tag, Parentname, sourceTag)
				end if
			else
				theUfSession.Wave.AskLinkSource(theFeature.Tag, true, sourceTag)
				If sourceTag = Tag.Null Then
					lw.WriteLine("could not fully load parent file...")
				Else
   				End if
			End if
		Next
	End if
Next
End sub
I receive an error:
Code:
Failed: NXOpen.NXException: The first parameter passed in was invalid.
   w NXOpen.UF.UFWave.AskLinkSource(Tag linked_feature, Boolean allow_load, Tag& source_entity)
   w NXJournal.reportComponentChildren1(Component comp, Int32 indent) in C:\Users\...\AppData\Local\Temp\NXJournals41836\journal0.vb:linee 218
   w NXJournal.Main() in C:\Users\...\AppData\Local\Temp\NXJournals41836\journal0.vb:line 75
Line 75:
ReportComponentChildren1(c.RootComponent, 0)​
Line 218:
theUfSession.Wave.AskLinkSource(theFeature.Tag, true, sourceTag)​
With best regards
Michael
The program has the following logic (simplified pseudocode):
Code:
IF linked feature THEN
    link broken? - get broken source
ELSE
    ask link source
END
Which basically says to check the link source on a feature that is NOT linked.
Also note that not all linked features will contain the word "LINKED" in the feature type. The following code from GTAC shows a more robust method to identify linked features.
www.nxjournaling.com
Thanks @Cowski now I see it. I used "else" in wrong place. I know that not all features has "Linked", but in my work I only use linked body and sometimes Linked mirror. For this two link I wanna find parent, and then check if it isn't from the different order. I will check the link You provided.
With best regards
Michael
I finally finished my journal. I used some part of code from NXjournaling. Below is the code, maybe it will be useful for someone.
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Public class PList1
	Public Property Part_Name As String
	Public Property Link_Name As String
	Public Property Parent_Name As String
	Public Property Link_Status As String
Public Sub New(ByVal PartN As String, ByVal ParentN As String, ByVal LinkN As String, ByVal LinkS As String)
'Public Sub New(ByVal PartN As String, ByVal LinkN As String, ByVal ParentN As String, ByVal LinkS As String)
'Public Sub New(ByVal PartN As String, ByVal ParentN As String)
	Part_Name = PartN
	Link_Name = LinkN
	Parent_Name = ParentN
	Link_Status = LinkS
End Sub
End Class
Module wave_links_part_only
	Dim theSession As Session = Session.GetSession()
	Dim theUfSession As UFSession = UFSession.GetUFSession
	Dim PartList1 as New list (of PList1) ()
	Dim List1 as New List (of String)
	'Dim Lista2 as New List (of String)
	Dim List3 as New List (of String)
	Dim List4 as New List (of String)
	Dim List5 as New List (of String)
	Dim List6 as New List (of String)
	Dim lw As ListingWindow = theSession.ListingWindow
Sub Main()
	If IsNothing(theSession.Parts.Work) Then
		'active part required
		Return
	End If
	'Dim workPart As Part = theSession.Parts.Work
	lw.Open()
	Dim searched_string as string
	searched_string = Inputbox("Please enter searched string. Minimum 3 chars.", "Enter searched string.", " ")
	If searched_string = " " Then
		MsgBox("You have to enter searched string.", vbOKOnly, "Error")
		Exit Sub
	ElseIf searched_string = "" Then
		Exit Sub
	End If
	If Len(searched_string) < 3 Then
		Msgbox("You have to enter minimum 3 chars to continue.", vbOKOnly, "Error")
		Exit sub
	End If
 	Try
		Dim c As ComponentAssembly = dispPart.ComponentAssembly
		if not IsNothing(c.RootComponent) then
			ReportComponentChildren(c.RootComponent, 0)
		else
			lw.WriteLine("Part has no components")
		end if
		Catch e As Exception
		theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
	End Try
	if Not IsNothing(Partlist1) AndAlso Partlist1.Count > 0 Then
		'Partlist1.sort(Function(x, y) x.part_name.CompareTo(y.Part_name))
		partlist1.sort(AddressOf Comparer)
		lw.writeline(" ")
		lw.writeline("*************************************************************")
		lw.writeline("*               Parts with searched links:                  *")
		'lw.writeline(" ")
		lw.writeline("-------------------------------------------------------------")
		lw.writeline("|  Part name  |  Parent name  |  Link name  |  Link Status  |")
		lw.writeline(" ")
		Dim Prt1 as String = nothing
		Dim Prt2 as String = Nothing
		for each Part_ as PList1 in Partlist1
			if Part_.Parent_Name.Contains(searched_string) then
				Prt1 = Part_.Part_Name
				If Prt2 = nothing then
					lw.writeline(Part_.Part_Name & " | " & Part_.Parent_Name & " | " & Part_.Link_Name & " | " & Part_.Link_Status)
				elseif Prt2 <> Prt1
					lw.writeline(" ")
				else
				end if
				Prt2 = Prt1
			end if
		next
	end if
	lw.Close()
End Sub
' Empty run
Sub reportComponentChildren( ByVal comp As Component, ByVal indent As Integer)
		Try
				'lw.writeline("   Error: " & child.DisplayName & ".prt" & " -> " & "Part is closed")
				list4.add(child.name)
				Continue for
			end if
			Catch e1 As Exception
				theSession.ListingWindow.WriteLine("Failed: " & e1.ToString)
		end try
		Else
			'component could not be loaded
		End If
		reportComponentChildren(child, indent+1)
	Next
End Sub
' Looking for Links
		Try
				Continue for
			end if
		end try
			Const undoMarkName As String = "report wave links"
			Dim markId1 As Session.UndoMarkId
			markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
	 		if not list3.contains(MyPart.leaf) then
				list3.add(MyPart.leaf)
				Dim theWaveLinks As New WaveLinkReport(mypart)
				ReportWaveLinks(theWaveLinks, False, mypart)
			End if
		Else
		End If
		reportComponentChildren1(child, indent + 1)
	Next
End Sub
Sub ReportWaveLinks(ByVal someLinkReport As WaveLinkReport, ByVal suppressNull As Boolean, ByVal mypart As Part)
	If suppressNull And someLinkReport.WaveFeatures.Count = 0 Then
		Return
	End If
	If someLinkReport.WaveFeatures.Count = 0 Then
		Return
	End If
	lw.WriteLine("")
	lw.WriteLine(mypart.leaf & ":")
	lw.WriteLine("")
	Dim status as String
	For Each temp As WaveFeature In someLinkReport.WaveFeatures
		For Each parent As String In temp.WaveParents
			If temp.IsBroken Then
				lw.WriteLine("    " & parent & "  ->  " & temp.Feature.GetFeatureName & " -> Link is broken! ")
				status = "Broken"
			Else
				lw.WriteLine("    " & parent & "  ->  " & temp.Feature.GetFeatureName)
				Status = "Alive"
			End If
			Partlist1.add(new PList1(MyPart.name, Parent, temp.Feature.GetFeatureName, status))
		Next
	'lw.WriteLine("")
	Next
	lw.WriteLine("")
End Sub
' Function loading components
Private Function LoadComponent(ByVal theComponent As Component) As Boolean
	Dim thePart As Part = theComponent.Prototype.OwningPart
	Dim partName As String = ""
	Dim refsetName As String = ""
	Dim instanceName As String = ""
	Dim origin(2) As Double
	Dim csysMatrix(8) As Double
	Dim transform(3, 3) As Double
	Try
		If thePart.IsFullyLoaded Then
			'component is fully loaded
		Else
			'component is partially loaded
		End If
		Return True
		Catch ex As NullReferenceException
			'component is not loaded
			Try
				theUfSession.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin, csysMatrix, transform)
				Dim theLoadStatus As PartLoadStatus
				theSession.Parts.Open(partName, theLoadStatus)
				If theLoadStatus.NumberUnloadedParts > 0 Then
					Dim allReadOnly As Boolean = True
					For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
						If theLoadStatus.GetStatus(i) = 641058 Then
							'read-only warning, file loaded ok
						Else
							if not list5.contains(partname) then
								'641044: file not found
								lw.WriteLine("File not found: -> " & partName)
								list5.add(partName)
								allReadOnly = False
							else
								'lw.WriteLine("	File not found: -> " & partName)
								allReadOnly = False
							end if
						End If
					Next
					If allReadOnly Then
						Return True
					Else
						'warnings other than read-only...
						Return False
					End If
				Else
					Return True
				End If
				Catch ex2 As NXException
					if ex2.message = "File not found" then
						if not list6.contains(partname) then
							lw.WriteLine("Error: File not found" & " -> " & partname)
							list6.add(partName)
						else
							'lw.WriteLine("	Error: " & partname & " -> " & "File not found")
						end if
					else
						lw.WriteLine("Error: " & partname & " -> " & ex2.Message)
					end if
					Return False
			End Try
			Catch ex As NXException
				'unexpected error
				lw.WriteLine("error: " & ex.Message)
				Return False
	End Try
End Function
' Compare component function
Private Function Comparer(ByVal x As Plist1, ByVal y As Plist1) As Integer
	Dim result As Integer = x.Part_name.CompareTo(y.Part_name)
	If result = 0 Then
		'result = x.Link_name.CompareTo(y.Link_name)
		result = x.Parent_Name.CompareTo(y.Parent_name)
		If result = 0 Then
			'result = x.Parent_Name.CompareTo(y.Parent_name)
		end if
	End If
	Return result
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
	'Unloads the image immediately after execution within NX
	GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
Public Class WaveLinkReport
	Private cSession As Session = Session.GetSession
	Private cUfSession As UFSession = UFSession.GetUFSession
	Private cPart As Part
	Public Property Part() As Part
		Get
			Return cPart
		End Get
		Set(ByVal value As Part)
			cPart = value
			Me.ExamineFeatures()
			Me.FindUniqueParents()
		End Set
	End Property
	Private cWaveFeatures As New List(Of WaveFeature)
	Public ReadOnly Property WaveFeatures() As List(Of WaveFeature)
		Get
			Return cWaveFeatures
		End Get
	End Property
	Private cUniqueWaveParents As New List(Of String)
	Public ReadOnly Property UniqueWaveParents() As List(Of String)
		Get
			Return cUniqueWaveParents
		End Get
	End Property
	Public ReadOnly Property NumberOfBrokenLinks() As Integer
		Get
			Return cBrokenLinks.Count
		End Get
	End Property
	Private cBrokenLinks As New List(Of WaveFeature)
	Public ReadOnly Property BrokenLinks() As List(Of WaveFeature)
		Get
			Return cBrokenLinks
		End Get
	End Property
	Public Sub New(ByVal thePart As Part)
		Me.Part = thePart
	End Sub
	Private Sub ExamineFeatures()
		For Each tempFeature As Features.Feature In cPart.Features
			If IsWaveFeature(tempFeature) Then
				Dim newWaveFeature As New WaveFeature(tempFeature)
				cWaveFeatures.Add(newWaveFeature)
			End If
		Next
	End Sub
	Private Function IsWaveFeature(ByVal theFeature As Features.Feature) As Boolean
		Dim wave2 As Boolean = False
		'check for wave linked sketch
		'linked sketches can be internal to another feature (such as an extrude)
		'so check for a WaveSketch feature before running the .IsInternal check
		If TypeOf (theFeature) Is NXOpen.Features.WaveSketch Then
			wave2 = Me.IsWaveFeature2(theFeature)
			Return True
		End If
		'some features create links within the part file (extract face, instance geometry, etc)
		'if the feature .IsInternal, odds are good it links to something in this part file
		'and not an external file
		If theFeature.IsInternal Then
			'skip features such as "mirror geometry" or "instance geometry" that do not link to another part
			Return False
		End If
		'check for wave linked datum
		If TypeOf (theFeature) Is NXOpen.Features.WaveDatum Then
			Return True
		End If
		'check for wave linked point
		If TypeOf (theFeature) Is NXOpen.Features.WavePoint Then
			Return True
		End If
		'check for wave linked curve
		If TypeOf (theFeature) Is NXOpen.Features.CompositeCurve AndAlso theFeature.FeatureType = "LINKED_CURVE" Then
			Return True
		End If
		'check for wave linked face
		If TypeOf (theFeature) Is NXOpen.Features.ExtractFace AndAlso theFeature.FeatureType = "LINKED_FACE" Then
			Return True
		End If
		'check for wave linked region
		If TypeOf (theFeature) Is NXOpen.Features.ExtractFace AndAlso theFeature.FeatureType = "LINKED_REGION" Then
			Return True
		End If
		'check for wave linked body
		If TypeOf (theFeature) Is NXOpen.Features.ExtractFace AndAlso theFeature.FeatureType = "LINKED_BODY" Then
			Return True
		End If
		'check for wave linked mirror body
		If TypeOf (theFeature) Is NXOpen.Features.MirrorBody AndAlso theFeature.FeatureType = "LINKED_MIRROR" Then
			Return True
		End If
		'check for wave linked routing object
		If TypeOf (theFeature) Is NXOpen.Features.WaveRouting Then
			Return True
		End If
		'none of the above...
		Return False
	End Function
	Private Function IsWaveFeature2(ByVal theFeature As Features.Feature) As Boolean
		Dim lw As ListingWindow = cSession.ListingWindow
		lw.Open()
		'lw.WriteLine("feature: " & theFeature.GetFeatureName)
		'lw.WriteLine("owning part: " & theFeature.OwningPart.Leaf)
		Dim theSourceEntityTag As NXOpen.Tag = NXOpen.Tag.Null
		Dim owningSourcePartTag As Tag = NXOpen.Tag.Null
		Dim allowLoad As Boolean = True
		Dim owningPartName As String = ""
		Try
			'.AskLinkSource throws error if link is internal to the part being processed
			'(simple hole, mirror geometry)
			cUfSession.Wave.AskLinkSource(theFeature.Tag, allowLoad, theSourceEntityTag)
			cUfSession.Obj.AskOwningPart(theSourceEntityTag, owningSourcePartTag)
			cUfSession.Part.AskPartName(owningSourcePartTag, owningPartName)
			If ex.ErrorCode = 1105004 Then
				'first parameter passed in was invalid (not linked to external geometry?)
				'lw.WriteLine("NX exception: " & ex.ErrorCode & ", " & ex.Message)
				'lw.WriteLine("")
				Return False
			Else
				'lw.WriteLine("")
				Return False
			End If
		Catch ex As Exception
			lw.WriteLine("Exception: " & ex.Message)
			lw.WriteLine("")
		End Try
		'lw.WriteLine("source part: " & owningPartName)
		'lw.WriteLine("current part: " & theFeature.OwningPart.FullPath)
		'lw.WriteLine("")
		If owningPartName.ToUpper = theFeature.OwningPart.FullPath.ToUpper Then
			'lw.WriteLine("IsWaveFeature2: False")
			'lw.WriteLine("")
 			Return False
		Else
			'lw.WriteLine("IsWaveFeature2: True")
			'lw.WriteLine("")
			Return True
		End If
		'lw.Close()
	End Function
	Private Sub FindUniqueParents()
		For Each tempWF As WaveFeature In Me.WaveFeatures
			If tempWF.IsBroken Then
				cBrokenLinks.Add(tempWF)
			End If
			For Each tempString As String In tempWF.WaveParents
				If Not cUniqueWaveParents.Contains(tempString) Then
					cUniqueWaveParents.Add(tempString)
				End If
			Next
		Next
		cUniqueWaveParents.Sort()
	End Sub
End Class
Public Class WaveFeature
	Private cFeature As Features.Feature
	Public Property Feature() As Features.Feature
		Get
			Return cFeature
		End Get
		Set(ByVal value As Features.Feature)
			cFeature = value
			Me.ExamineFeature()
		End Set
	End Property
	Private cParents As New List(Of String)
	Public ReadOnly Property WaveParents() As List(Of String)
		Get
			Return cParents
		End Get
	End Property
	Private cIsBroken As Boolean = True   'assume link is broken
	Public ReadOnly Property IsBroken() As Boolean
		Get
			Return cIsBroken
		End Get
	End Property
	Private cIsAccepted As Boolean = False  'assume it is not broken intentionally
	Public ReadOnly Property IsAccepted() As Boolean
		Get
			Return cIsAccepted
		End Get
	End Property
	Public Sub New(ByVal theFeature As Features.Feature)
		Me.Feature = theFeature
	End Sub
	Private Sub ExamineFeature()
		Dim sourcePart As String = ""
		Dim sourceId As String = ""
		cUfSession.Wave.IsLinkBroken(cFeature.Tag, cIsBroken)
		If cIsBroken Then
			cIsBroken = True
			cUfSession.Wave.AskBrokenLinkSourcePart(cFeature.Tag, sourcePart, sourceId)
			cParents.Add(sourcePart)
			cUfSession.Wave.AskLinkAcceptBroken(cFeature.Tag, cIsAccepted)
		Else
			'link NOT broken
			'ref: nx_api4930
			Dim theInfo As UFWave.LinkedFeatureInfo
			cUfSession.Wave.AskLinkedFeatureInfo(cFeature.Tag, theInfo)
			Dim sources() As String = theInfo.source_part_name.Split(",")
			'wave feature may have multiple parents; e.g. the mirror body
			'  mirror plane may be owned by a file other than the file that owns the body
			For Each prtSource As String In sources
				cParents.Add(prtSource)
			Next
		End If
	End Sub
End Class
With best regards
Michael
