HOW IS SEAL CLASSIFIED
Metal Parts
Rotating Face
Gaskets
Stationary face
Any other material not covered. Please include
A well phrased question has answers in itself!!!
RE: HOW IS SEAL CLASSIFIED
The normal material combinations of a mechanical seal should be:
1. Rotary face
2. Stationary face
3. Spring/Bellow material
4. Elastomers
5. Metal parts
The springs/bellows should be separated normally because in many situations srings/bellows may need using different and special materials such as different alloys.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
