PWHT of Monel 400
PWHT of Monel 400
PWHT of Monel 400
Can anyone give me any insight into the Brinell Hardness requirements for Monel 400 after PWHT for pipe? Is it in the range of 160-185 BHN? I also can not find any information regarding at what hardness levels does Monel 400 become susceptible to cracking. I have seen some documentation suggesting it may be in excess of 140 BHN. Thanks
RE: PWHT of Monel 400
In case the type of the cracking is sulfide (H2S) stress corrosion cracking, maximum hardness limit for monel (UNS N04400) is 35 HRC.
Refer to below reference.
1) From NACE MR 0175 / ISO-15156-3, table A.13
"UNS N04400 and UNS N04405 shall have a maximum hardness of 35 HRC."
2) From NACE MR 0103, clause 14.1.1.6
"Wrought UNS N04400 and N04405, and cast ASTM A494 Grades M35-1, M35-2, and M30C
shall not exceed 35 HRC."
Lee SiHyoung,
WorleyParsons Oman Engineering,
Thank you Lee
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Understanding Critical Specifications for Dynamic Metrology Applications
Different types of metrology have different critical specifications to consider when determining which actuator technology to use. This white paper goes into detail on the demands of dynamic metrology applications as they apply to the selection of precision linear motion control components and systems. In addition, the relevance of Moore's Law is examined in the context of the industry. Download Now
White Paper - Permanent Non-Welded and Cold Bent Piping Solutions
Commonly used welded piping connections come with skilled labor, validation, inspection, and long commissioning times, as well as the workplace hazards associated with welding. Non-welded permanent mechanically attached fittings offer a viable alternative to welded piping systems that greatly reduces the time to commission piping systems through reductions in many of the time-consuming steps required in welding. Download Now
White Paper - Take Mobile Hydraulic Systems to a New Level
The introduction of digital ecosystems connecting electronic control hardware and software to the Cloud is catalyzing a new era of mobile machine and equipment design innovation. This is enabling OEMs across industries to develop customized solutions that digitally integrate hydraulic and machine controls with the Internet of Things (IoT). Download Now
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
