Dear Experts
We faced failures of casting version of Ni-alloy 800H (manaurite 800) after thermal ageing. Operation is at 500°C and excursions at 620°C are anticipated (coke burning). Failure was by crack propagation and no corrosion was experienced. Mechanical test of failed tubes showed total loss of toughness at ambient temperature.
It seems to me this can be some kind of "sigma phase embrittlement" of Ni-alloy 800H but sigma phase formation normally requires a ferrite phase and Ni-alloy 800H is supposed to have very low (zero ?) levels of ferrite. Can there be a ferrite phase or another phase in austenitic structure of casting Ni-alloy 800H that can promote sigma phase formation ?
Can sensitization by chromium carbide precipitation at grain boundary produce significant loss of toughness at high temperature for casting of Ni-alloy 800H ?
Do you see any other metallurgical transformation that can occur at 500-620°C on casting Ni-alloy 800H and that can lead to loss of toughness ?
Which countermeasures (chemical limitations, grain size, ...) would you advise in order to avoid loss of toughness of Ni-Alloy 800H after thermal ageing at 500-620°C ?
Which bad fabrication practice could induce such low ductility of Ni-Alloy 800H (wrong heat treatment / casting conditions) ?
thanks in advance
regards
thanks in advance
regards
