'This callback allows the dialog to enable/disable the OK and Apply button.
Hi
The doc say:
'This callback is executed when any block (except the ones which receive keyboard entry such as Integer block) receives focus.
'This callback is executed when block which can receive keyboard entry, receives the focus.
But for enableOKButton_cb it only say:
But not 'This callback is executed when
Do someone know when This callback is executed ?
CODE -->
    'Callback Name: focusNotify_cb
    Public Sub focusNotify_cb(ByVal block As BlockStyler.UIBlock, ByVal focus As Boolean)
        Try
            '---- Enter your callback code here -----
            'msgbox(block.ToString & "  -  " & focus.ToString)
        Catch ex As Exception
            '---- Enter your exception handling code here -----
            theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
        End Try
    End Sub
    'Callback Name: keyboardFocusNotify_cb
    Public Sub keyboardFocusNotify_cb(ByVal block As BlockStyler.UIBlock, ByVal focus As Boolean)
        Try
            'msgbox(block.Name)
            'string1.Focus
        End Try
    End Sub
    'Callback Name: enableOKButton_cb
    Public Function enableOKButton_cb() As Boolean
        enableOKButton_cb = IsEnableOkButton
        Try
            'Return IsEnableOkButton
        End Try
    End Function
RE: 'This callback allows the dialog to enable/disable the OK and Apply button.
THANK YOU IN ADVANCED
enableOKButton_cb gets called after every interaction with the dialog. You have the option to check if all the required inputs have been satisfied or not. You can return true to enable the OK button or false to disable it.
Suresh
www.technisites.com.au
Hi ufsure and thank you.
That's strong my guess.
Thanks.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Reshoring Prototyping and Production
In this whitepaper, we'll provide insight into why and when it makes sense for U.S. manufacturers to reshore prototyping and production, and how companies can leverage the benefits of working with local design, prototype, and manufacturing partners during the pandemic and beyond. Download Now
Engineering Report - Top 10 Defect Types in Production
This 22-page report from Instrumental identifies the most common production defect types discovered in 2020, showcases trends from 2019 to 2020, and provides insights on how to prevent potential downtime in 2021. Unlike other methods, Instrumental drives correlations between a variety of data sources to help engineers find and fix root causes. Download Now
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
