how to execute different analysis types subsequently using RESTART in ansys apdl
C.A
24
Hi to all
I was wondering is it possible to execute two different analysis types ( first static and second transient) using RESTART ?
the problem is such a way that I have to run first load step statically (because for converging I must do Rezoning mesh and it is applicable in static analysis).second load step will run in transient process.
a valuable comment in this context using TIMINT command and negligible structural and thermal effect.but at first load step ans the restart and finally using TIMINT and turn on thermal effect.but by considering this trend,Rezoning mesh is not possible.
is there a way , we run first load step statically and then import result file to use in transient analysis at second load step?
any comment would be appreciated.
CYRUS
