ANSYS APDL - Pressure analysis on simple cylinder VS cylinder with irregular feature
braunboise
Petroleum
Jan 7, 2019
3
I am trying to do a simple 2D pressure analysis on a cylinder with notches/steps on the OD and ID of the cylinder. Pressure was applied on a portion of the OD and ID but the result of the analysis shows a heavily distorted cylinder which don't look right to me. Note that i constraint the geometry by applying symmetry to the bottom most line of the geometry to the Y axis (code below)
LSEL,S,LINE,,1,,,1
DSYM,SYMM,Y
ALLSEL
I tried to simplify the problem and created a cylinder with straight ID/OD and applied the same boundary condition and pressure but didn't see the distortion as the irregular shaped cylinder. Do i need to apply additional constraint/BC to the irregular shaped cylinder if so, where should the additional constrain be applied and why the different BC from the regular shaped?
Nodal displacements in most FEA postprocessors are scaled by some value (like x10...x1000) for better understanding of results by default. You can set scale factor to desired value.
Link
