Need help with symbol interpretation
kevlar49
Materials
When a groove weld joint is already partially beveled and a you specify a symbol with a v groove but do not specify the depth of the groove, is it interpreted as weld through the bevel into the backside or just start from the bottom of the v-groove. See my alternate interpretations in the attachment. The reason why I ask this is AWS A2.4, Figure 20F seems to imply this.
 https://files.engineering.com/getfile.aspx?folder=cdf5ffd1-8c43-465b-b209-655bfc228ec3&file=Symbol_interpretation.pptx
I think you should ask the engineer what it intent was.
faq731-376
If there is no depth of preparation indicated in the symbol, it is assumed to be full penetration. Your interpretation 'B'.
The generic V-groove symbol without any dimensions is a CJP.
Best regards - Al
