High Performance Coating
daviv
My project requires the contractor to apply a high performance coating to a canopy located at a cruise terminal. The specification states the steel which is hot-dipped galvanized shall be prepared in accordance to SSPC-SP2 (Hand Tool Cleaning)before the application of the primer. On the other hand, the supplier's preferred method of surface preparation is Abrasive Blast Cleaning which the contractor considers is a change order and will extend our project beyond what we would like. My question is Hand Tool Cleaning sufficient, with an inspector from a testing inspecting present during the coating process?
Abrasive blast may likely abrade the galvanizing, removing some or all of the corrosion protection afforded by the zinc.
Would hand tool cleaning be sufficient?
Does "supplier" = primer manufacturer ?
I'd call the primer mfr's tech support, and not deviate from their recommendation.
I expect they publish detailed documents answering your exact question.
Are there finish coat surface quality expectations/requirements for the canopy?
High-performance coatings protect steel and other metals by creating a highly durable barrier between the metal and its service environment.
A high-performance coating on the other hand, can add a level of durability from light scuffing that is quick and easy to clean while simultaneously adding a pop of color to the surface.
