Journal Add workpart to TaggedObejct
I writing small journal for export pdf, dxf, parasolid and step for each part in assembly.
I can select all parts in assembly, but I can't add main part (or workpart) to selection group.
I use standard function:
Is it possible to do this?
Best regards
MANox
CODE --> vb
Function SelectComponents(ByVal prompt As String, ByRef selObj() as TaggedObject) As Selection.Response Dim theUI as UI = UI.GetUI Dim title As String = "Select components" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim selectionMask_array(1) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_all_subtype End With With selectionMask_array(1) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_part_occurrence_subtype End With Dim resp as Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selobj) If resp = Selection.Response.Ok Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function
Best regards
MANox
RE: Journal Add workpart to TaggedObejct
Would love to get this capability!
Good luck
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX11, Win 10 Pro
Isn't better to process all parts in assembly than selecting each part by MaskTriple?
With best regards
Michael
sometimes I must export all parts, sometimes only few part.
My problem is - how select assembly (no all part - I think about assembly file in assembly tree).
This moment I do it like that:
CODE --> vb
CODE --> vb
Best regards
MANok
NX11/12
TC10
Look at this thread, maybe this will help. thread561-346964: NX Journal Selection Priority
With best regards
Michael
I start from beginging:
1. I have assembly with (p.ex) 5 components.
2. I want open drawing for each component and for assembly.
3. I want export drawing to pdf and dxf and component and assembly to stp, x_t and igs (full assembly and for each component).
My joural do all of these.
But when I selected components to export, I can select only component, I can't select assembly.
I want ask - is it possible to add some maskTriple to select assembly (GD-01.000 on attached movie).
Best regards
MANok
NX11/12
TC10
