I writing small journal for export pdf, dxf, parasolid and step for each part in assembly.
I can select all parts in assembly, but I can't add main part (or workpart) to selection group.
I use standard function:
Is it possible to do this?
Best regards
MANox
Code:
Function SelectComponents(ByVal prompt As String, ByRef selObj() as TaggedObject) As Selection.Response
Dim theUI as UI = UI.GetUI
Dim title As String = "Select components"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = False
Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
Dim selectionMask_array(1) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_component_type
.Subtype = UFConstants.UF_all_subtype
End With
With selectionMask_array(1)
.Subtype = UFConstants.UF_part_occurrence_subtype
End With
Dim resp as Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selobj)
If resp = Selection.Response.Ok Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
Best regards
MANox
