Journal Add workpart to TaggedObejct
MANox
PL
I writing small journal for export pdf, dxf, parasolid and step for each part in assembly.
I can select all parts in assembly, but I can't add main part (or workpart) to selection group.
I use standard function:
Code:
Function SelectComponents(ByVal prompt As String, ByRef selObj() as TaggedObject) As Selection.Response
	Dim theUI as UI = UI.GetUI
	Dim title As String = "Select components"
	Dim includeFeatures As Boolean = False
	Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
	Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
	Dim selectionMask_array(1) As Selection.MaskTriple
	With selectionMask_array(0)
		.Type = UFConstants.UF_component_type
		.Subtype = UFConstants.UF_all_subtype
	End With
	With selectionMask_array(1)
		.Subtype = UFConstants.UF_part_occurrence_subtype
	End With
	Dim resp as Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selobj)
	If resp = Selection.Response.Ok Then
		Return Selection.Response.Ok
	Else
		Return Selection.Response.Cancel
	End If
End Function
Is it possible to do this?
Best regards
MANox
I can't help you but I'm all about this tool.
Would love to get this capability!
Good luck
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX11, Win 10 Pro
Isn't better to process all parts in assembly than selecting each part by MaskTriple?
With best regards
Michael
sometimes I must export all parts, sometimes only few part.
My problem is - how select assembly (no all part - I think about assembly file in assembly tree).
This moment I do it like that:
Code:
Select Case Msgbox("Add assembly too?", MsgBoxStyle.YesNo, "Select assembly too?")
       Case 6
           Add_assembly = true
End Select
and after:
Code:
If Add_assembly = true then
'code
End if
But I would like select assemby with parts selection, if it's possible.
Best regards
MANok
NX11/12
TC10
Please provide some example how your structure looks. What You have in main assembly? Solid body, sheet body, etc. ?
Look at this thread, maybe this will help. thread561-346964
With best regards
Michael
I start from beginging:
1. I have assembly with (p.ex) 5 components.
2. I want open drawing for each component and for assembly.
3. I want export drawing to pdf and dxf and component and assembly to stp, x_t and igs (full assembly and for each component).
My joural do all of these.
But when I selected components to export, I can select only component, I can't select assembly.
I want ask - is it possible to add some maskTriple to select assembly (GD-01.000 on attached movie).
Best regards
MANok
NX11/12
TC10
 https://files.engineering.com/getfile.aspx?folder=49ea4bb8-7f1d-4a50-9710-e4b707498983&file=movie.avi
