Selection of corrossion test G28/G48
Dear All,
We are having injection quill fittings.Material grade is inconel 625.
As we are referring the flange specification(SAMSS- Saudi Aramco standard),its having requirement of corrosion test G28. But for the same grade material (inconel 625) fittings is having requirement of corrosion test with G48.
Can i know the possible reason from anyone that for same material grade , why two type of corrosion test specified ...??????
RE: Selection of corrossion test G28/G48
Actually they are both important. They test for different characteristics.
Have you read the two test methods?
For G48 your customer would need to supply a method, temperature, and acceptance criteria.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
