Elastic-Plastic Analysis - Determine the maximum load for a burst test
David Browne
GB
Hello all,
I'm using ANSYS 18.2 Workbench Enterprise.
I am running an elastic-plastic analysis in accordance with ASME VIII Div 2 Part 5 where I wish to determine the maximum pressure load at the point I am predicting the design to gross plastically collapse.
Is there an easier and more efficient way of being able to set a range of input pressures then running for all those values until the solver does not converge?
Currently I'm running as-standard by inputting the pressure, doing a step load with program-determined sub steps, awaiting the result at which point the model doesn't solve then making note of that pressure in which the model doesn't solve - THIS TAKES FOREVER!
Is there a better way? Is there an in-built iterative way?
Kind regards,
David.
