Bad Performance with new PC
Hello everyone, i'm Carlo and i recently refreshed my workstation:
OLD: i7 4790k 32GB RAM DDR3 Quadro k2000
NEW: i7 7820x 32GB RAM DDR4 Quadro k2000
But now i've noticed that: UGS NX 11.0 takes more time for render/export a project than before (I have old values). Is that normal? hyper threading can affect? I need it ON.
Thanks everyone. Carlo
RE: Bad Performance with new PC
Why do you need hyperthreading on? It effectively only gives you 1/2 of your processor to a single-threaded application like NX. What are the processor speeds for the i7-4790k and the i7-7820x? That may be you issue.
Ben Loosli
Are you also talking about the same NX versions on both PC's?
Ow and it is Siemens NX11 not UGSlol
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
The 7820x benchmarks slower than the 4790k for single thread operations.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Reliability Verification for AI and ML Processors
Artificial intelligence and machine learning are seeing growing adoption in a wide range of applications. ICs used for AI/ML applications are characterized by large parallel processing computation units, high power dissipation, and complex circuitry that can deliver maximum performance within a strict power budget. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
