Yield strength of SA 387 GR 11
Mert-41
8
Dear all experts,
I am trying to simulate the welding process of SA 387 GR Cl 2 material using FEA.
But I need the Yield Stress of SA 387 varied with temperature also I should use yield strength as dependent on time.
Where Can I find out these material Properties?
Best regards...
Not sure about time-dependent properties but Table Y-1 in ASME Section II Part D lists the yield strength values of SA-387 Gr11 Cl2 plate from 100°F to 1,000°F.
-Christine
Thank you for your advise Chrisine...
Dear Experts Yes I have found Yield stresses value dependent on temperature Asme Section II Part D table Y-1 but Could I find tangent modulus?
