Wrapping in EXCEL 2003 1
JohnCerny
6
Greetings,
I know that there is a limit on the characters that can successfully be wrapped in EXCEL, to some degree. I still can't figure out how to resolve my problem. The only way presently to fix the probelm is to auto-size the cell. For example, I have the following in a cell:
Measure the OIP3 (dBm) for the RMC FRU, and calculate the IIP3 using the formula, OIP3=IIP3+Gain. Or, measure the IIP3 and calculate the OIP3.
This test is the standard two-tone test. There are three sources of error that should be considered when making distortion measurements on devices with low intermodulation products. These three are:
1) Interaction between the test equipment
Ensure that there is adequate isolation between the two signal generators. Use Isolators, LPFs, attenuators and amplifiers if available to increase the isolation. If resistive power combiners aren't available, use Mini Circuits family of 2-way, 0 degree power splitters, such as ZFSC-2-5. Tie spectrum analyzer and two generators together via 10 MHz reference.
2) Dynamic range of the spectrum analyzer
The usual quick check to determine if the analyzer in generating internal distortion due to input signals that are too high, is to increase the analyzer's input RF attenuator by 10 dB and verify that there is no change in the signal level of the IM products. If the IM product levels do change when the input attenuator is switched, the analyzer is generating internal distortion products and the input signal level is too high to make a valid measurement.
3) Quality of equipment
Use the 8644A or equivalent low-noise generators for greater sensitivity.
Choose a spectrum analyzer with adequate dynamic range, such as a Agilent E4440 or equivalent
Some of the cell wraps, but some doesn't wrap. There are already "ALT-Enter" commands in the cell, but yet there still is a problem. What must I do to see and print all that actually is within a cell? Thanks for your consideration.
John
For that much text, it might be best to use a text box (on Drawing toolbar) instead of trying to put everything in one cell. Alternatively, use several cells and use Edit|Fill|Justify to wrap into the cells desired.
Well, there are many cells like this, and there are more columns as well. Picture a 6 cell wide by 50 cell long document that fits on 17 pages. Another program exports the data to EXCEL, and then I format the report to look nice, and then print it out. Using text boxes is not realistic in this case.
Why on earth are you using Excel? Surely Word would work better?
Like I said, the database program (DOORS) generates the reports in EXCEL, and the report works just fine in EXCEL, but there is one formatting issue. PLease just tell me if you know how to resolve my problem, and not comments on how you would do it. I am stuck with the tools that we are forced to use. Thanks
Is it possible to use the cells for the headline comments and use the "INSERT/Comment" menu to add the rest of the description in the comment box?
ANy one who wants to then clicks on the red triangle to see the comment which woul be the bulk of your text.
e.g. in the cell put:
"Measure the OIP3 (dBm) for the RMC FRU, and calculate the IIP3 using the formula, OIP3=IIP3+Gain. Or, measure the IIP3 and calculate the OIP3."
and put the rest in the comment "This test is the standard two-tone test. There are three sources ....." etc.
JMW
This will ultimately be printed out, so that idea, though having merit, will not work.
Thanks.
John
Which report in DOORS are you referring to?
Why can't you directly export to Word?
TTFN
I suppose that it can be taken from EXCEL into WORD. I hadn't thought of it. DUH! I will try it and see how it looks. Thanks. Our version of Doors creates requirements docs in WORD, but test plans in EXCEL. Go figure!
John
It may be of interest to note that this particular piece of text actually exceeds the stated limit of Excel to display in a cell. This passage is 1207 characters long (1448 including spaces). According to Excel 2003 help for Excel Specifications and Limits:
Excel 2003 Help said:
Length of cell contents (text):
32,767 characters. Only 1,024 display in a cell; all 32,767 display in the formula bar
I guess this limit is either outdated or (as I suspect) it is the supported limit, and anything you get above that is a bonus but unpredictable.
HOw does save an EXCEL file as a WORD file, or are you thinking to copy and paste the entire file, which looks hairy.
John
If you select a bunch of cells in Excel and paste them into Word they will come in (at least on my machine) as a Word table that you can easily adjust size, formatting, wrapping, whatever you want.
Yes, but the problem in the OP was that Excel is not designed or intended for large blocks of text in a single cell, and it is therefore difficult to control formatting, wrapping, etc. Inserting an Excel object into Word would do nothing for that issue. Pasting, however, creates a Word table that is designed to be able to hold, format, wrap, etc. large amounts of text in a single cell.
If you save the Excel file as a text file, you can open it in Word and the individual cells will come in with quotation marks around each cell entry.
I just tried it in OpenOffice and it seemed to take it OK. Download from OpenOffice.org - a replacement for Microsoft Office Suite.
Although a large number of characters can be placed in a single cell only about 256 can be displayed at one time. By default the first 256 are displayed. If you want to display more than 256 you must reference the cell containing the text with a mid function. Suppose a1 holds the text then
=mid(a1,1,256) will show the first 256
=mid(a1,257,256) will show the next 256
and so on
You can facilitate display by letting another cell hold the starting point for viewing, say a2
=mid(a1,a2,256) will show the first 256 if a2=1
if you want you can add a spin button with the linkcell set to a2 so you can change the starting point by clicking the spin button. By setting teh large change property to 256 you could flip through 256 charactor chuncks of your report
for each click of th espin button.
256 is the column limit - the number of characters in a single line that can be displayed in a cell. None of the lines in the OP come near 256 characters in length.
Paste the text from the OP into a single cell (you have to paste it to the formula bar) and you can see the entire text displayed in the cell. As stated before, this is outside Excel's stated limits, but it works. However, formatting is squirrely, hence the OP.
Handleman,
I just tried that in Excel 2002 and it didn't work, after the first few wraps, it gives up and the only way to see the sentences is to drag the column width out.
JMW
