WPS Parameter limits
Ani18
Petroleum
QA
Dear experts pls clarify my doubts,
As per asme sec 9 position is not an essential variable for WPS .
Let consider I have a pqr qualified in 1G position as per code I can use that WPS for Vertical position welding but by doing so how can I choose the parameters correctly.
The current range required for root run in flat position will it give sufficient penetration and fusion in vertical or overhead position?
How can we select it?
Hire somebody with the knowledge/experience to be able to make decisions like this without using an internet forum to bolster your own lack of knowledge / experience.
