My question is regarding the essential variables of a WPS. B.31.1 is applicable code. The company has a WPS for 6010 downhill root and 7018 uphill out. The skilled welder has qualified to this procedure. The company would like to run a 6010 downhill out procedure for some upcoming work. It is my understanding that weld progression is non essential on the WPS and that qualifying on F-4 group electrodes will also qualify the welder for F-3 group. My confusion is wether a NEW WPS needs to be written and qualified for 6010 downhill out by the company or if a WPS previously qualified by the welders previous employer is suiable. Thickness range, base metal groups are the same, test position is /was 6G in all instances. I understand a new WQR will be needed in either case. Any help with this would be greatly appreciated.
