Woodgrain hatch, autocad.pat 1
trishp
Computer
I am trying to find the autocad.pat file, but I can't find the file in the autocad support area. Is there another way to find this file so that I can add the woodgrain to my hatch patterns
Hi trishp,
You didn't mention the version of AutoCAD you're using so the easiest thing to do search for *.pat, more than likely it'll turn up in C:\Users<your username>\AppData\Roaming\Autodesk\...
HTH
Todd
I tried that and I still don't find that file. I have AutoCad 2006.
Hi trishp,
Did you look in this directory: C:\Users\<your username>\AppData\Roaming\Autodesk\... ?
Todd
Code:
(findfile "acad.pat")
____________________
Civil 3D 2008, Terramodel
