Method #1
Turn off the Merge Control option and use the DRAWORDER command so that the drawing will print the way you want.
Method #2
Do not use wipeouts. Instead, delete the areas of the drawing that you do not want to print.
Note: You could also move the objects to a non-printing layer, but the objects will still be displayed on screen.
