DTS419
- Jun 21, 2006
- 181
I find R301.2.1 in IRC to be very unclear as to when wind design is and is not required. The first sentence reads "Buildings and portions thereof shall be constructed in accordance with the wind provisions of this code using the ultimate wind speed in Table R301.2 as determined from Figure R301.2(2)." That is basically just a table that is filled out with the wind speed from a map. So at this point it would seem that any residential structure must be designed for wind, similar to how you would under IBC except maybe the wind speed is a bit different as determined by the local building official.
Then we get to R301.2.1.1 which says "The wind provisions of this code shall not apply to the design of buildings where wind design is required in accordance with Figure R301.2.1.1, or where the ultimate design wind speed Vult in Figure R301.2.(2) equals or exceeds 140 mph in a special wind reason." Both those referenced figures basically are high wind regions in coastal areas, and in fact the title of the former is "Regions Where Wind Design is Required."
So, does a residential structure that is not within a high wind coastal area (as shown in Regions Where Wind Design is Required) need to be designed for wind at all? If so, what is the difference between R301.2.1 and R301.2.1.1?
