dgkhan,
I would recommend a repair, and design a repair that unequivocally restores the original strength, and show that by calculation.
That way, if there's an issue in the future, you are covered, and it is the original design that was at fault.
I bet that if you can show by calculation, that a 1/2 inch of local bending / twist / warp, whatever you want to call it still checks out as OK, you've probably omitted a crucial calculation, unless the loading conditions have reduced from the original design.
tg
