electricpete
As has been discussed before on this forum, typical practice for some folks after replacing a bearing is as follows:
Do a blue check or a dry roll check to estimate the contact pattern between the shaft and the babbit.
Scrape to get the desired contact pattern (> 80%).
What is the purpose of this procedure?
To my way of thinking, the cylindrical geometry of the sleeve should be a natural result of manufacture. The diameter of bearing should be a little larger than shaft to develop a wedge. The clearance can be checked separately by plastigage. Also important to note, the position where the shaft rests during blue check (bottom dead center) is much different than where it will sit while running.
So... I don't get what it is that we are trying to gain through this blue-check and scraping procedure.
