I have been working on modifying Half-Bridge PC supplies, and so far no problems with that.
However, I find it strange, I need something like 230W from the 230V AC mains, if my total output load is only 140W DC.
I have used a true power meter on the AC, so Voltage-Current phase should not be the problem.
The heat build-up in the supply may be something like 10-20W, but where do the remaining 70-80W go ?
If I look at the +/- 160V DC going into the transformer primary, everything seems to fit.
Is there some sort of a form factor when peak rectifying AC to DC involved here ?
