canwesteng
- May 12, 2014
- 1,710
I'm designing some rigging, and I'm debating whether to use the equations for a pin or to check shear and bending together for the pin below the crane hook. The contact surface should be flat, and there won't be much gap between the ends of the pin and the hook, but the hook itself is 2.5" wide. I usually use pin equations for stuff at most half that thick. Anyone have any insight, maybe some knowledge on how shackles are designed?
