I have a 5/16" pin connecting two shafts together via a loose press fit. The outer shaft has an outer diameter of 3" and an inner diameter of 0.875". The inner shaft is solid with a diameter of 0.8734".
The applied load is approximately 20 ft-lb of torque.
My question is how to approach this problem. Should I neglect the bending since the gaps are small or should I include the bending moment in? I think I'm over thinking it.
