when does the pressure vessel fill with nitrogen?
kangar20
8
Hi
I have a question : when do we fill the vessel with nitrogen?
I'm looking for a spec or standard that help me .
When you want to exclude / remove potentially explosive vapours.
Very vague question so a rather vague answer
Or for preservation as an alternative to desiccants.
Or to push liquid out of a tank.
Please give more details.
For oceanic transport to prevent corrosion
r6155
Are some large fabricated vessels shipped from shop to site inerted? I've noticed some large, equipment being shipped with what looked like a few N2 cylinders strapped to the side.
When the pressure vessel is a nitrogen cylinder?!
Couldn't help myself- the question is so totally vague to be of absolutely no help to anyone including the OP...
When the contract says to... :)
When you mix it up with another job and accidentally put it in the drawing.
I think the OP might have gone to check it out in person....
To be slightly serious kangar - Nitrogen inerted vessels kill people on a yearly basis when they enter them without realising it as there is no smell or odour, just a very serious lack of oxygen.
when the vessel if for nitrogen service then you must fill with nitrogen.
r6155
Kangar20,
I know two other reasons when Nitrogen is used in a system:
1. I've seen thermal oil systems expansion tank with Nitogen "blanket". This is done in order to avoid oxidation of oil because of high temperatures.
2. Another example I have seen Nitrogen is used for emergency instrument air supply in case if compressors are down. Nitrogen was stored under pressure in liquid form in a tank.
Curtis
