Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
No, because without the CF, each of the diameters (separated by the groove) could be within position tolerance and within their own size tolerance, but the virtual condition could be larger than the maximum size.If the positional tolerance is applied on rfs basis, as long as the positional tolerance is smaller than the size tolerance, the two different callouts (2X vs. <CF>) would mean the same.
Yes, I think this would be correct.If the positional tolerance is applied on mmc basis, the positional tolerance has to be zero to make the two callouts mean the same.
Belanger said:No, because without the CF, each of the diameters (separated by the groove) could be within position tolerance and within their own size tolerance, but the virtual condition could be larger than the maximum size.
