onlym112
- Sep 9, 2019
- 45
Can anyone please explain to me what the difference is between bolt plowing and bolt bearing? I am reading a paper from Larry Muir and William Thornton on "The Development of a New Design Procedure for Conventional Single-Plate Shear Connections" that talks about how bolt plowing and bolt deformation in a conventional shear tab is what guarantees the required rotational flexibility of a simple shear connection. It seems to me that bolt bearing is the same as bolt plowing unless the latter is elastic deformation and the bearing is plastic?
Thank you
Thank you
