I'm in the early stages of investigation on a project using CO2 for EOR. The CO2 may have some moisture initially, but when the oil is being extracted through the wells, there will be oil, gas, and water. Therefore, all the CO2 separating equipment will be exposed to wet CO2.
The options that I am considering for piping materials are coated carbon steel, and I'm investigating 304 and 316 SS. The information I've looked at is leaning towards using 316.
Is this a good choice for a piping material? The system will be seeing temperatures of up to 300 degrees F and pressures up to 2500 psig. The higher pressures will see separated and dry CO2 but the lower pressures will definitely see wet CO2.
Thanks in advance,
Viewsonic
Thanks in advance,
Viewsonic
