Our fabrication shop typically welds a 1/2" thick T1 steel to a 3"thick x 11" wide 4130 steel "tire" (circular section). The 1/2" material is welded to the inside of the "tire" at approx. 26 places. The shop preheats the "tire" with propane rosebuds to 150 deg. F. at numerous positions while the "tire" rotates. While the tire is at the 150 deg. F., a man places the 1/2" T1 plate onto the inside of tire and a second man tacks the 1/2" plate to the tire using MIG. The weld wire is .035 and 100ksi. Once plate is tacked, the welder welds two oval shaped holes (approx. 2.5" wide x 3" tall) with approx. 3 or 4 complete circular passes - they do not fill the oval hole completely. They continue this process until all T1 plates have be welded to the tire. The assembly is then removed from the preheating/welding jig with no further postheat treatment except for cooling down at shop ambient temperature. This tire rotates with a load on it and the T1 plates (spokes) flex from tension to compression in its rotation - sort of like a bicycle tire.
We have experienced cracking on one side of the oval holes that runs square to the long axis of the ovals and the crack goes from one side to the opposite side of the T1 plate.
My concern is for our lack of "Welding Procedures" that address the preheat and postheat requirements. We do not employe a Welding Engineer or a Metallurgist to help with this problem.
Do you think our shop practice is correct?
Thanks very much,
First Time Inquirer, Long Time Reader
Thanks very much,
