I hope this is the right place to ask this question. If you have Brazed Plate Heat Exchangers that are CE approved (meet ASME requirements), and they are supplied with stub connections, can flanges be welded on these stub connections legally per code(s) or do they require additional testing and inspection and need to have the equivelent of an "R" stamp on them? Sorry to be so vague, but this is something we are concidering and we're not sure if after welding these heat exchangers to put flanges on if they will still be acceptable per ASME and CE (PED) requirements. These heat exchangers would be part of the system that I asked about the "R" stamp on the pressure vessel. The entire system must meet CE (PED) requirements which means it must meet ASME requirements.
