Welding command - cant find it
FlashT
11
I am quite new to NX and would be grateful if someone could help me out with this problem. I have welded some parts together with a command I found somewhere in NX. I need to do some changes on the weld but cant seem to find the command. The only welding command that I find is "Weld assistant" wich I do not have a lisence for.. are there other weld commands, or did some kind of "demo" time expire?
Best regards,
FlashT
Were you working in history mode? If so, look in your part navigator to see the name of the features that were created. You can use the 'command finder' to search for the command that created those features, or search for keywords like 'weld', 'unite', 'join', etc.
