Welding Code for Stainless Steel Sheet Metal
anhly
I am interested to learn more about continuous welding code for stainless steel sheet metal. Where could I buy or obtain these codes via the interenet? Thanks in advance
Usually the welding code is dictated by the end use of the produce, such as boilers (ASME), or airplane parts (D17.1), but for a general code that addresse stainless steel and sheet, a good staring point is AWS B2.1.
AWS B2.1 is not a code, it is primarily a standard for qualifying welding procedures and welders.
AWS D1.6 is the structural welding code for stainless steel, but it is for materials 1/8 inch or thicker.
If I remember correctly, the structural sheet metal code is primarily for carbon steel. I have a copy around here somewhere, the the devil is trying to locate it.
Best regards - Al
Best regards - Al
Al,
Good point about the "Code". However, depending on the thicknesses being used, D1.6 could be applicable as it goes down to 1/16" (2mm) or 16 gage.
